Gareth
Gearknob removal?
XantiaMan
- x 18
Gearknob removal?
How do you get the gearknob off a Xantia? No funny answers please!
Gareth
Gareth
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
elma
- x 287
alan s
- RIP 2010
- x 6
Over here it's not a problem as they get rotten in the sun and fall apart.
The problem we have is trying to get a knob that will fit on the shaft if you can't find or don't want an original.
The shaft is basically the same size all the way up, but at the top where it goes into the actual knob, it has been pressed into a + shape and has a thread tapped onto the legs of the +, hence it is not actually screwed on but more forced on so once removed, I doubt would ever be refitted in a way that could prevent it falling off in your hand at every gearchange.
Most knobs that can be bought at auto accessories stores don't allow for the + configuration, but in fact only have 3 instead of 4 pieces to hold the knob in position. They also have very tiny grubscrews to use as a retainer that are set to hold on the 3 leg set ups.
On mine, I had to drill the centre hole out and use epoxy to make it solid, so unless you really need to remove it, my best advice would be leave it where it is or what seems like a simple job can make a mess of a Saturday afternoon.
Alan S
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
XantiaMan
- x 18
The knob in question is currently on an Activa so its worth trying to get the thing off, if it needs bonding on i have suitable stuff at work i can use..
Gareth
Gareth
2017 Fiesta ST
2017 Fiesta ST
