1. Turbo boost gauge tubing.
2. High current wiring
3. N2O tubing
For #1, I'd like the shortest possible route. The tubing will be attached to the small pipe that operated the fuel pump diaphragm - unless there is a better place to plumb into? I don't know where to mount the gauge either - was thinking of modding the ashtray or an air vent
For #2, I intend to re-wire the horns - don't ask! - and will also be needing to route the wiring for the N2O. Would prefer a neat as job as possible while the length of run isn't important.
For #3, this is heat critical, the cooler (relatively) the better. The tubing will run through the bulkhead into the engine bay and on to the soleniod, which should be mounted somewhere relatively cool and solid like the inner bodywork. Additionally, the tubing from this solenoid is ideally as short as possible which is plumbed into the air intake, anywhere from from the intercooler to the inlet manifold.
All suggestions and comments most welcome, thank you.
