Picking up a replacement ram tomorrow, the lip that holds the sphere seal in place on my old one has corroded away to the point it no longer holds the seal (and fluid!) in place... I've got new rear spheres to fit anyway, and a new hyd pipe for the body, but does anyone have any advice/tips on changing the ram itself?
It appears pretty straightforward, but there's bound to be a catch.....
Xantia rear suspension ram - advice on changing?
reddeathdrinker
'96 Xantia 2.0i 16v SX Estate
AndersDK
The catch is - you HAVE to remove the sphere to get out the suspension cylinder.
There is no other way !
- unless you want to angle grind the chassis frame to bits.
The job is therefore very much the same as replacing the wheel sphere.
It can prove impossible to remove the lock pin from the cylinder rod in the end of the arm. Be sure the lock pin truly has its time over a couple of 24hr's with genuine rust solution. Its the only way.
Drilling it out will make a large hole damaging the arm for good.
Anders (DK) - '90 BX16Image
reddeathdrinker
Thanks Anders - I had the sphere off anyway, and new ones waiting to go on
I have the pin out, bit rusty, but easy enough to punch through. The base of the ram seems to be corroded into the suspension arm, so I'm posting this whilst having coffee, leaving it soaking in WD40
Mandrake
- x 694
Wow you guys really do have problems with rust up there don't you.reddeathdrinker wrote:Thanks Anders - I had the sphere off anyway, and new ones waiting to go on
I've just removed the suspension cylinders on mine to do rear arm bearings and had no problems with anything being rusted... thats not to say that I didn't have other problems though....
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
pprado
Well, to say something that was awkward to do on reassembly of mine: the vent pipe and the LHM return pipe.
There is almost no space to put your hand, or even pliers, to push the pipe on.
(I needed to remove mine because I loosened the gaiter from the rod end one time, just to find out that I could not put it back whithout pushing the rod from the cylinder end...)
Pedro Prado
Pedro Prado
reddeathdrinker
Mandrake
- x 694
I'll second that, after just having refitted them... luckily I have long skinny fingers well suited to the jobreddeathdrinker wrote:Yup, they were awkward...pprado wrote:Well, to say something that was awkward to do on reassembly of mine: the vent pipe and the LHM return pipe.
Regards,
Simon
Simon
1978 CX 2400
1978 CX 2400
