Megane Scenic clutch
elma
x 284
Unread post by elma »
My parents have a megane scenic 2.0 rxe. I think its a y plate.
I drove it for the first time recently and the clutch is horribly stiff.
They've owned the car since new and renult have serviced it all its life. I think its on the original clutch.
Is it normal for it to be quite a stiff pedal?
I'm thinking that the cable is simerley routed to on my xantia and so probably needs replacing. If that is the case does it have the same fiddly clip on the pedal as my citroen?
