I have a 405 TD (M-1994) that has a redlight that comes on as you switch on the ignition but then goes off after a couple of seconds.
I noticed today that it came on whilst driving, notably cornering, and I don't mean on 2 wheels!
Any suggestions please, I could find nothing in Hayes or the owners handbook.
Warning light on Airbag?
philhoward
There's a connector which joins the moving steering wheel to the static wiring for the rst of the car (namely the seat sensors and a power supply) - my guess is the rotary connector is on its way out..it's hitting a temporary dead spot and resetting the ECU (which is in the steering wheel itself).
The 2 second light on starting is correct - it's the system self check.
woodhead722
Clogzz
- x 40
No risk of the airbag deploying when the red light is on.
It’s actually the firing of the bag that’s temporarily disconnected where the slipring doesn’t make contact.
My 1995 Xantia has a sticker on the door pillar that says that the airbag is only good until January 2004.
After that, it may no longer deploy if the fabric has rotted at the folds.
Peugeot said since that they were good for 15 years.
2002 C5 2.0i AL4 239,000 km 76372389
- x 1431
My First Xantia used to do this. The control unit for the airbag is in the wheel centre on these early cars, hence the red light on the wheel. Repeated powering up of the bag can't be good for it, and it might deploy unexpectedly
- you'd probably be best advised to replace the 'clock spring' / rotary connector or whatever Pug/Cit call it.
woodhead722
moodle
moodle
Many thanks, will take a look tomorrow -DaiRees wrote:Lots of trouble with connectors under the front seats on the 306s and 406s, could be the cause of your problem moodle. Not sure what colour it is on the 306 (orange connector on the 406 IIRC), so get under there and make sure they're all secure.
moodle
np
moodle
Thanks for the replies which are helpful as I would never have looked under the seat at the connectors there -
I don't know if this makes any difference to the prognosis but I switched the air bags of with the key overide - the warning light telling me they were switched off (yellow) flickered exactly the same -
Going to have a proper look tomorrow now that have finished on my veg mobile
Mmm that sounds like my connectors, they feel very weak and dont give any confidence of a good solid 'snap' together -np wrote:My warning light came on late last year.I checked the connectors under the seat & sprayed some wd40 on them,even though they looked fine.Turned out to be dry solder joints on the seat connectors.A common problem on all PSA cars.Had them re soldered which cured it.
moodle
