This is a problem troubling a good pal's car so this info may be a bit
second hand...
Nice car that runs very well apart from an annoying habit of cutting back
the power as though there's a fuel blockage/air leak. The engine coninues
to run but there's no point as the car wont accelerate/pull at all well.
A restart usually always creates a reset and the car runs happily once
more!! when it plays up the k symbol on the dash illuminates so the
ECU thinks there's a problem. I don't have a fault code reader though.
If the fuel pump/delivery is electrically controlled on a 'drive-by-wire'
system is there a known weakness/failre point that would fix this problem?
Ideas/suggestions?
Andrew
110bhp Xantia HDi cutting out/loss of power & k symbol
andmcit
- x 30
- x 1466
dexy350
got the same problem on mine,checked the vacuum on the turbo waste gate ok i have swapped the 2 egr valves over this sorted the problem out for a bit now it looks like the other has gone engine management light back on loss of power ,so ordered a new one which is arriving monday £68 hole in the pocket for 1. going to put this in the egr for the turbo wastegate and take it from there.
cheers
dexy
cheers
dexy
Dexy
C5 2.2 HDI SX 02
C5 2hdi exclusive est 06
C5 2hdi exclusive 09
C5 2.2 HDI SX 02
lolingram
- RIP 2010
I have been runiing my HDi Xantia for a year now with the EGR solenoid disconnected.... runs slightly sweeter at low revs, and doesn't coke up the inlet valves.
Passes MOT no sweat, so the conclusion is pretty obvious.
cheers
dexy
________
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
