Juddery Wipers on 306
demag
x 102
Unread post by demag »
W reg 1.9d
The problem is juddery wipers when the switch is on delay/auto. Full speed constant is ok.
This problem is on the return/park stroke only. There are two purple(?) relays and the left hand one is clicking. When I swapped the relays the problem is still there. I cleaned the terminals on the connector block near the motor but no difference.
Is this the motor? I hope not it looks a right pig to get out. :( Or is it the auto circuit from the windscreen sensor? I somehow doubt the latter.
Any ideas?
Thanks,
Dave.
Dave
philhoward
Unread post by philhoward »
Sadly, sounds like a dodgy earth through the parking switch...which is most likely inside the motor itself...or is in the Lucas 14W which is the only one i know well!
