Hi again,
Recently, the joint going from the pipe to the backbox of my V6 rusted to nothing and gave way, at first it wasn't too bad, but then it broke away and there was no silencer. NOT good, the thing was unbearably LOUD!!!
Since, i've stuffed a pipe inside the back box and slotted it into the broken pipe and put some exhaust sealant to 'quieten' it. The sealant keeps breaking up and makes the car noisy again (not unbearable)... Anyway, I have a few ideas to quieten it, but my main question is... Is it safe/sensible to leave it like this for long, i.e, will the cat.conv be damaged, fuel consumption higher etc etc.
The noise is verrry nice if not a bit loud, so I may leave a little hole there.
Broken Exhaust question
AndersDK
DickieG
- Monaco's youngest playboy
- x 38
I've just replaced that pipe on my V6, either http://www.buypartsby.co.uk/exhausts_de ... cordID=378 or http://www.eurocarparts.com/ appeared to be the cheapest.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
deian
'Temporary' standard bodge, I don't believe in doing things by half, but in this case it will have to be like this for a while... until my funds recover from getting married in July, and the need to buy drop links and an acc.sphere.
We don't get along with my neighbour anyway, it can't be worse than his stupid camper van with a manky engine (read: black smoke).
Those prices are surprisingly cheap! Excellent stuff. Thanks
dnsey
- x 19
caveman_si
You can also use silicone sealeant on exhaust BUT only if the joint is down stream so to speak of the lamda sensor and the cat.
Ive used it a few times and I have found it gives a great seal and as a side effect means if you need to take the exhaust apart it comes apart quite easily.
Harley davison have been putting their exhausts together that way for years.
406 lx 1.9td estate
lolingram
- RIP 2010
Don't you mean Massey Davidson
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
deian
Stempy
Both made in the same factory
Lexia ponce
Lexia ponce
lolingram
- RIP 2010
ACTIVE8
- x 6
