Does this bit of my Xantia suspension look right to you?
Izzard
Unread post by Izzard »
Hi folks. Could someone please have a look at these two photos and tell me if it's normal?
(1997 'P'-reg Xantia 1.8i LX hatchback)
In each case I have highlighted the part I'm interested in with a white outline. It's a metal D-shaped hoop.
Suspension set to lowest position:
...and the highest position:
The reason I'm asking about it is that the loop is open and appears to stretch and 'slay' apart when the height-selection lever is moved to the upper position.
I'm wondering if I'm looking at something which is about to break!
AndersDK
Unread post by AndersDK »
Its a spring clip and is supposed to stretch/compress.
Looks alright to me.
Any functional problems with the suspension ?
Anders (DK) - '90 BX16Image
Izzard
Ah, well then that's fine! Thanks :)
Height selection and raising/sinking is all working fine. The only reason I was taking a look is that the ride has recently got noticeably firmer and is kicking me up the bum on bumps, etc. So I've been doing some citrobics and spraying WD40 everywhere as a first port of call, before I spend money on parts.
Mandrake
x 694
Unread post by Mandrake »
Looks weird doesn't it - almost as if it is broken, but it's normal. :lol:
Provided it is maintaining the ride height accurately its probably just the spheres aging and losing gas - it creeps up on you at first and then over a relatively short time can start to get very obvious.
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Izzard
Well I always say: "Why do today what you can put off 'till tomorrow?".. ..so I'll let it creep up on me a bit longer I think :D
