non return valve
geof
non return valve
Unread post by geof »
hello, ive got a xantia td and the fuel bulb needs pumping in the mornings to start it. ive read that you can get a non return valve to fit in the system. can anybody tell me where to get one from ( lincos / halfords etc ) geof.
jeremy
Unread post by jeremy »
Probably better to find the air leak. If its got a Bosch pump have a look at the leakoff pipes first.
jeremy
x 1240
Unread post by Peter.N. »
Cant help you with a non return valve I'm afraid, but that't only treating the symptoms. You obviously have an air leak some where, allowing the fuel to drain back to the tank. Check all the fuel pipe joints for tightness and also the fuel filter cover, also the leak off pipes or possibly the fuel bulb itself. If you can park your car for a while facing steeply downhill, the leak should manifest itself as fuel leakage.
x 1240
You obviously type faster than me Jeremy!
geof
thanks, will do that also when i have time. geof
weety
Unread post by weety »
you can buy the non return valves of e bay but i would agree you are better of fixing the problem rather than the sympton ........
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
