Now got a fuel leak
MikeT
x 232
Now got a fuel leak
Unread post by MikeT »
Following the LHM leak (now cured) I quickly noticed a small patch of vegetable oil under my car which I've identified as dripping (appx 1 drop per min) from the base of the fuel pump. It appears to leak only when the engine is running.
I can't see exactly where it's coming from so thought I'd post here to hopefully get a few pointers on where to look before I have to start removing parts to see all clearly.
Having run 100% veg oil for several hundred miles I'm suspecting it's either pump, pipe or connector. Is the pump serviceable?
Thanks,
Mike
jeremy
Unread post by jeremy »
Could be the pump shaft seal which is replaceable. The procedure will probably be different for Bosch and Roto-Diesel pumps. You may find instructions on here if you search but I'm not certain.
jeremy
MikeT
x 232
Sorry, should have said it's a BOSCH (will try and find which model exactly) :oops:
I've read they can better withstand the higher viscosity of veg oil so I'm hoping it's nothing substantial that's failed.
Searching the forum now
jeremy
It nay be one of the semi electronic pumps - which are broadly similar to a mechanical with some of the linkages replaced by electronics.
Diesel pumps are fine pieces of engineering and eminently repairable. They are made to extremely fine tolerances and all work must be done in such a manner to prevent any dirt getting into the thing. There are many independent specialists who can be found through yellow pages and whose charges are usually reasonable.
jeremy
MikeT
x 232
Well I've looked and looked and looked and I can't see where it's coming from. It doesn't appear to be from the inlet pipe to the pump. Nor from the injector feed pipes and I'm pretty sure it's not from the return feed.
I'll get a diesel pump specialist to look at it if I have to (any recommendations in Christchurch/Dorset?) but cannot afford to spend money on anything I could do myself. Are there exploded diagrams for these pumps that I could view?
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
mike
try this out not sure how pricey they may be :(
http://www.boschautoparts.co.uk/bdl/loc ... tProduct=1
try www.boschautoparts.co.uk
then dealer/agent locater
colin
MikeT
x 232
Thanks Colin, didn't think of trying BOSCH direct :oops: :lol:
I spoke to a guy at Electro Diesel and he's quoted labour at £45 p.h. +VAT (diagnosis appx 90mins) or for a full pump service appx £350+VAT incl. parts.
What I did find interesting/worrying was when he hypothesised(sp?) "...if the pump has been contaminated in some way..." I hope not!
jeremy
How can it take 90 minutes to tell you its got an external leak? Somehow I think there are more useful experts around and he's trying to make a simple job look difficult.
jeremy
MikeT
x 232
I tend to agree, for when I told him £350 is about the worth of the car he then agreed to "pop his head under the bonnet and get an idea of what's what" if I just turn up at his premises. :lol:
I may pop in tomorrow morning but observations today show the leak has either lessened (barely a drop or two while parked) or it's taking a new path under the car and has yet to saturate the area enough to drip onto the ground :?
weety
Unread post by weety »
i have had diesel pumps go on XUD's i havent been running on veggy (so i think its cruel to blame the poor vegetables :D )....
just get yourself another diesel pump they are about £100 from a specialist citroen breaker and who knows how much from a little scrappy
really really easy to change as you bolt the flywheel in position and then just remove the pump (no need to worry about engine timing)
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
lolingram
RIP 2010
Unread post by lolingram »
I got one off eBay for £15 in good nick
I understand that XUD generic Bosch with turbo diaphragm inlet connection are pretty well universal - especially those before the coded starting electrics which is the way to go IMHO
have had diesel pumps go on XUD's i havent been running on veggy (so i think its cruel to blame the poor vegetables Very Happy )....
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
MikeT
x 232
weety wrote:i have had diesel pumps go on XUD's i havent been running on veggy (so i think its cruel to blame the poor vegetables :D )....
Ok, it was a best guess I admit and I'd read veg oil is 5-7 times thicker than diesel.
Apologies to any disgruntled rapeseeds.
MikeT
x 232
Went to a local BOSCH service centre and he estimated £650 for a full pump service/rebuild. I told him another centre quoted me £350+VAT and so he advised I go there :lol: like they do.
Obviously I don't want the full rebuild, just the leak cured which I'm hoping will be within my meagre budget but one thing he said that concerned me was that it may "upset the balance" requiring full testing and calibration at further cost.
Apart from my elderly parents complaining of the stain I leave on their driveway, I'm happy to leave it as it is for now.
lolingram
RIP 2010
Frankly, I cannot begin to understand why you would want to go down this route, when a good S/H one will cost peanuts...
Went to a local BOSCH service centre and he estimated £650 for a full pump service/rebuild. I told him another centre quoted me £350+VAT and so he advised I go there Laughing like they do.
Previously...
MikeT
x 232
I wouldn't take that route, the car cost me less. But the huge difference in quotes tells me it could be worth shopping around for a simple repair by a bosch trained mechanic.
How do you tell a good used pump pump from a bad one? I don't even know what model mine is and I've never removed or fitted one before, is it a straight replacement job?
I would have said my pump was a good 'un until recently :?
