it could be coincidence but the front pad sensor has now lit up albeit only when handbrake pulled full on and/or when brake pedal pressed right down
cant seem to find any sign of lhm leakage inside footwell but was not sure if it could the brake dosser on its way
i have a 1996 1.9td that has died and im going to be using this as a donor for bits and pieces so hopefully if its brake dosser i will be able to have a spare to hand
nearly forgot the donor car has abs and mine doesnt
colin
