How to top up the LHM
Barbarian
How do you actually go about topping up the LHM? I have checked it and its not between the markers when the car is on high mode. Although it is when on normal setting. How do you actually go about opening the LHM tank? I cant see where to open it? What is the correct procdure.
Xaccers
- x 186
Set the car on high, get some LHM.
On the top of the resovoir is a large rubber bung with a long tube coming out of it, pop that off and pour in LHM until the red part of the float is between the two orange lines.
DIY sphere tool
DIY sphere tool
- x 94
i have never seen a red float HE HE HE, all the ones i have seen look yellow to me, mind you i do wear glassesXac wrote:Set the car on high, get some LHM.
regards malcolm
Sturdybloke
