Hi there, nice forum.
Had this argument over whether or not you could feel and hear the ABS braking system when applied.
I said you could feel the pulse and some pedal drop - even hear grinding. Opponent totally denied this saying that the pulse was so fast, one couldn't feel it or know when ABS was acting.
Am I going mad? And were the ABS symptoms I felt and heard just a figment of my imagination?
Now owner of C5 Auto Diesel VTR - nice car
Please solve Citroen Xantia ASB brake debate
- x 8217
Hi and welcome to the forum!
On a conventional car with conventional ABS I believe you will feel the ABS working with a pulsing pedal.
On a Hydraulic Citroen though, a full hydraulic one but not your C5 which is, as I understand, pretty conventional in its braking, you won't feel it anywhere so much, just the effects of ABS bringing you very quickly to a controlled halt.
I have invoked the ABS a few times on both my Xantias, both on-purpose to test and during emergencies. All that happened was a controlled stop.
On my TD Xantia the ABS was non-operational when I first had the vehicle due to a duff sensor. After replacement of the sensor the difference was quite amazing. An emergency stop changed from being a full 4-wheel skid to a ful stop with no drama whatsoever whith no change of feeling in the pedal.
- x 1463
frenchcarnut
I used to feel mine all the time when it was working. It was like a nibble on the pedal. Anyway, the debate surrounded ABS in general, so I think I was fairly accurate.citrojim wrote:Hi and welcome to the forum!
frenchcarnut
jeremy
I've got it on my BX but I've only had it come on at slow speeds - when to be honest I wish it hadn't been there - like the time I nearly got a neighbour's cat as by the time the thing made its third pulse the car would have stopped with the wheels locked. I had a similar experience when someone opened a car door immediately in front of me in a narrow road with cars parked both sides. - How to make a crisis out of a drama.
In fact I drove the car for 6 months before I got it working - and I must say that to be honest out of all the cars I've had it needed it least.
My view of it is that at all costs I must drive carefully enough to prevent it working as although the car will not slew if it does cut in, its almost certain to increase my stopping distance.
We don't get much snow in Sunny Southampton but when we did get a little I tried it out just to see what happened - and again the thing seemed less likely to stop with it working that without. Certainly not a case of slamming on the brakes and coming to a smooth and rapid stop.
I think I get a certain amount of feedback through the pedal which is to be expected as the doseur displaces pressurised fluid as it operates - and so if the pressure of the fluid displaced varies - the pressure exerted on the valve - and eventually the pedal will vary as well.
jeremy
frenchcarnut
jeremy wrote:I think I get a certain amount of feedback through the pedal which is to be expected as the doseur displaces pressurised fluid as it operates - and so if the pressure of the fluid displaced varies - the pressure exerted on the valve - and eventually the pedal will vary as well.
Well that sounds like a fairly credible theory whilst the rate of pressure change due to fluid displacement would be different to action of the valve itself given physical constraints.
I've also read an academic abstract alluding to the issue of noise being down to action matching resonant frequencies within the structure of the car when the ABS kicks in.
jeremy
- x 8217
It is interesting the you other Xantia owners report you can feel the ABS working and yet I never have in either of mine.
Now, either I'm not braking really hard and not really bringing the ABS right into operation, quite possible as I'm a very gentle driver and my definition of an emergency stop may not be the same as others or it could be this:
The only times I've really gone for an emergency stop is when both cars had springs in their brake pedals. Perhaps the spring absorbs all the pulses or is it that I'm usually wearing heavy work boots when driving
I'll go do a test stop in the Activa over the next few days and see as the Activa now has the "solid spring" fitted in the brake pedal.
Homer
- x 16
I could never feel it activating on a dry or even a wet road, and I'm pretty sure I provoked it enough. Certainly took a bit of getting used to the (non ABS) BX after driving the Xantia.citrojim wrote:It is interesting the you other Xantia owners report you can feel the ABS working and yet I never have in either of mine.
The only times I did notice it were if I got one wheel on mud, in which case it was more a shuddering through the steering than the pedal. And on black ice at low speed when I could definitely feel it through the pedal.
Xaccers
- x 186
Jim, you'll have to take Dex out and do an emergency stop, on the 3 Xantia's I've owned, all gave feed back from the ABS.
DIY sphere tool
DIY sphere tool
Mandrake
- x 694
I can feel the ABS working on the pedal on mine - and hear it too.
Regards,
Simon
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Ross_K
- x 110
frenchcarnut
