Xantia oil Change - with extraction pump?
markw
Unread post by markw »
Hi, has anyone used an extraction pump (like this one: http://www.cdet.co.uk/catalogue/product ... ctid=PL650) to do an oil change? Can anyone forsee any issues?
Oil changes on my Xantia 1.9TD are a right pain at the minute - as the sump has at some point been cracked and the bottom plug welded into place.
Mandrake
x 694
Unread post by Mandrake »
A right pain ? :shock: How do you drain it at all without the bottom plug ???? :?
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
oldnail
Oil change
Unread post by oldnail »
Yes I have used one exactly the same with no problems.If you really do not want to change the sump you can get a cheaper version on Ebay for changing the oil on a Smart car which has no sump plug fitted,just search for Smart car suction pump.
Hope this helps,
oldnail.
LeeDJC
Unread post by LeeDJC »
Oooh, I like the idea of that! Saves messing around in under the car!
2004 Berlingo Multispace HDI, 105000
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Can't possibly see how this will give you a good oil change. There's bound to be at least a litre of old oil left on the floor of the sump.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
AndersDK
Unread post by AndersDK »
JohnD wrote:Can't possibly see how this will give you a good oil change. There's bound to be at least a litre of old oil left on the floor of the sump.
Dont think so John.
If you jack the car RHS front lift point and set the height to low, the oil will collect at LHS near the dipstick in the sump, which is where you probe with your pump.
Nothing close to a liter will be left, but maybe a couple of 100mL's. That is well adequate to ensure the oil is fresh.
Anders (DK) - '90 BX16Image
oldnail
Oil extraction
These types of extractors have been around in the motor trade for years. As I said on a Smart car you have to use one as theres no sump plug.They are used a lot in the marine industry due to the inaccessibility of a lot of boat engines
oldnail
Kowalski
Unread post by Kowalski »
People do talk about the advantages of speed, convenience and cleanlieness but they neglect to explain the disadvantages of an extraction pump.
When you remove your sump drain plug, the oil rushes out and carries out with it things that have settled in the sump, thats soot typically on a diesel. If you use a pump, you won't get the same flushing effect so the some of the sediment stays in the sump that would have been flushed out.
There are some situations where you have to use an oil extraction pump, for example in a boat where you can't get a container underneath the engine to catch the oil running out but the best method (short of removing the sump) is draining quickly by gravity via the sump plug.
JohnD
(Donor 2022)
x 72
[quote="AndersDK"]
quote]
Yes, I did envisage jacking the car to one side, but I still don't see how you know a flexy, curly plastic tube will go exactly where you want it to.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
reblack68
Unread post by reblack68 »
It's better than not changing the oil at all and I'm pretty sure most main dealers do it that way nowadays.
For any car that has sump plug issues I'd say it's a satisfactory solution.
Richard
Care of a 1994 205 D.
markw
Mandrake wrote:A right pain ? :shock: How do you drain it at all without the bottom plug ???? :?
Using the top plug and then using a single action pump to try and get as much of the rest out as possible from underneath - gets messy! And probably not giving it great oil changes..
oldnail wrote:If you really do not want to change the sump you can get a cheaper version on Ebay for changing the oil on a Smart car which has no sump plug fitted,just search for Smart car suction pump.
oldnail, - is the tube on the smart suction pump definitely long enough for a xantia? I can't find the length of the tube online, but imagine the smart engines are quite a bit shorter?
Village
Unread post by Village »
Turn the car upsidedown and give it a shake? It works with my piggy bank! :D
French car free zone....
steelcityuk
Unread post by steelcityuk »
I stick high power magnets on my oil filter in the hope it will trap ferrous metal particles that could be small enough to get past the element. I get the magnets from old PC hard disks. For free it's worth a try.
Steve.
not applicable
oldnail
Oil extraction
The extractor I've used is the Sealey vacuum type which comes with various size probes which go down the dipstick hole.Will empty out a 5Lt sump in minutes.
oldnail
AndersDK
steelcityuk wrote:I stick high power magnets on my oil filter in the hope it will trap ferrous metal particles that could be small enough to get past the element. I get the magnets from old PC hard disks. For free it's worth a try.
Steve.
GREAT tip Steve \:D/
