Veggie compatability
john alexander
Can anyone shine some light. I have a 2000 2litre hdi 406. I understand that it cant run on SVO due to the weak pump at the tank but it must be possible to run a diesel veggie mix to thin it down. Has anyone tried and what ratio of mix works.
AndersDK
HDI's are infameously expensive to repair, if the high pressure pump gives up the ghost. Thats the real problem.
The lift pump is not that expensive as its a low pressure type, and lots of aftermarket units may drop in as a direct replacement.
I would not risc my HDI with any experiments
Anders (DK) - '90 BX16Image
Xaccers
- x 188
General thinking is any SVO + direct injection = bad news.
Sell your car and get one slightly older with a XUD9TE engine and you'll be laughing.
Alternatively, play around with sulphuric acid and turn the SVO into nasty bio diesel and run on that.
DIY sphere tool
DIY sphere tool
OnlineCitroJim
- x 8406
Xac wrote:Alternatively, play around with sulphuric acid and turn the SVO into nasty bio diesel and run on that.
nick
There are companies which claim to be able to modify HDi's to run on veg oil eg,
http://www.smartveg.com/faqs/faqs.php?showid=30
weety
trouble is there arent many people running on veggy with HDI's (yet) so there isnt a lot of knowledge about what may go wrong long termnick wrote:There are companies which claim to be able to modify HDi's to run on veg oil eg,
whereas many many people have run XUD9's for many thousands of miles without problems
my vote is also to sell it and buy a slightly older car that you can run with minimal modification on a single tank conversion
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
OnlineCitroJim
- x 8406
It can only be a matter of time before four things happen...
1. Manufacturers wll market a diesel that will run on SVO with no problems trumpeting it, no doubt, as a very "green" car. They'll spin it for all it is worth.
2. Aftermarket kits will be produced to allow all modern diesels to run on the stuff.
3. Lucas will produce a kit of parts to allow their pumps to run SVO.
4. Supermarket forecourts will have Veggie Oil pumps. One supermarket will perhaps offer three: "Value", "As Good as the Leading Brand" and "Finest".
Seriously, it seems to me to be the way to go, even if say, PSA revert to the XUD with a mechanical Bosch pump to make it happen. At least those fields of yellow that make some of us sneeze in the spring will be growing something useful.
howiedean
Yes your right, I did this but got sick of noisey starts and reduced power (1.9 td). Two neighbours said my car sounded like a bag of spannersweety wrote:trouble is there arent many people running on veggy with HDI's (yet) so there isnt a lot of knowledge about what may go wrong long termnick wrote:There are companies which claim to be able to modify HDi's to run on veg oil eg,
Biofuel, veg oil is too thick I tried this with my previous xantia HDI and the bloody stuff wouldnt even pump from the tank (low pressure pump).
I do know someone who uses biofuel in a 306 HDI at 50% mix. He has to mix the fuel before it goes in the tank otherwise the thick stuff sinks to the bottom of the tank and it wont pump out then.
Regards
Howie
2006 Fiat Idea Dynamic 1.3 Multijet
2010 Renault Laguna Dynamique tom tom 2.0 DCI 130
C5 VTR 2l 8v HDI Estate 112000 miles gone
Kia Rio 2007 1.5 CRDI 62,000 miles gone
2001 Dodge Durango 4.7 V8 170,000 miles gone
1999 Ford Crown Victoria 4.6 V8 151,000 miles gone
weety
elsbett produced an engine donkeys years ago.....cant see manufacturers wanting to do it as (i understand it) they moved to common rail/hdi to reduce emissions in accordance with eu guidelinescitrojim wrote:It can only be a matter of time before four things happen...
kits are available (or you can just make your own) but no kit manufacturer would ever give you a gurantee it wouldnt damage your car2. Aftermarket kits will be produced to allow all modern diesels to run on the stuff.
some people have rebuilt lucas pumps so it is possible (if i recall the problem is shaft lubrication with cold thick veggy unable to travel quickly enough).3. Lucas will produce a kit of parts to allow their pumps to run SVO.
i can see fuel stations offering a veggy pump (probably next to their lpg one) but they would have to tax the fuel as above the exemption so their only customers would be extreme high usuage (above their own personal limit)4. Supermarket forecourts will have Veggie Oil pumps. One supermarket will perhaps offer three: "Value", "As Good as the Leading Brand" and "Finest".
we should be allright for years to come...last xantia with an xud 9 rolled of the line in about 99.....they last twenty years anyway so i think we dont need to worry until the mid 2020'sSeriously, it seems to me to be the way to go, even if say, PSA revert to the XUD with a mechanical Bosch pump to make it happen. At least those fields of yellow that make some of us sneeze in the spring will be growing something useful.
howiedean
Regarding the Mechanical pumps. I'm sure there is an outfit in brazil that is producing modern engines that use a mechanical pump. I read that some people have been retrofitting them into landies as theyare a similar size to a TD5 but without all the electronics.
Regards
Regards
Howie
john alexander
I reasearched around the web and the general feel was that a blend would be ok and to increase it till it starts to run off then cut it back. Having now seen your responses I'm now tempted to hang fire.
But before I got your replies I put a 14% mix in and so far covered 100 miles problem free. Its a 650 mile tank so if its sank i'm not safe yet but nothing ventured nothing gained.
The older car was where I came from and opted for the 406 for the safety of the new baby so I'll keep you's informed and if it goes well then i've saved £100 anually if not then
weety
the blend advice is for a single tank XUD9 conversion i cant see how you could get away without doing (at a minimum) a twin tank conversion with the second tank having an external fuel lift pumpjohn alexander wrote:I reasearched around the web and the general feel was that a blend would be ok and to increase it till it starts to run off then cut it back. Having now seen your responses I'm now tempted to hang fire.
James.UK
Howie.
My ZX starts the same, runs better, and is quieter.. I have no complaints or problems whatsoever when using 100% veg oil in my car..
If the car starts to play up on starting when the weather cools off, then I will reduce the mixture to suit conditions..
Did I mention that I LOVE my ZX 1.9D auto...
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
LeeDJC
weety
never worked on a HDI but i believe the pump is situated in tank....veggy oil and the pump wont mix very well...hence twin tank with external pumpLeeDJC wrote:I thought that the problem with veg oil in an HDi wasn't the pump, but the sensors measuring the viscosity of the fuel, not liking the thickness of SVO - or am I way out? I'm sure I read it somewhere....
and cold veggy is much more stodgy than diesel (its why the name of the game is to get it to 70 odd degrees as quickly as possible)....the HDI is looking to move fuel through its system very quickly at high pressure and i cant see it coping with cold veggy
