Just to throw a spanner in the works of my testing of the effect of air bubbles on the ride, it seems that my Hydractive system has developed an electrical sensor fault
I still have the electrovalve LED connected after more than a year and in that time the soft/hard electrical switching has been pretty flawless, but now it is staying in hard mode at all times above 25Km/hr
I first noticed a problem a few days ago where it seemed like the straight ahead calibration was out - this is something that can occasionally happen as the steering wheel sensor has no centre position (it's an optical chopper disc) and straight ahead is determined by computer heuristics.
The symptom is that for a while the car can be in hard mode while driving straight ahead, and yet soft when turning in a specific direction. After a minute or so of driving the computer figures out that the centering is wrong and recaculates the centre position.
That happened a few times over the last few days but since yesterday it is staying in hard mode permanently above 25Km/hr - every time I slow down below that speed it switches back to soft mode.
The speed sensor must be ok if it knows whether I'm above or below that speed, and the throttle sensor is still working too. When I get home I'll have a look at the fault tables to confirm it, but I'm pretty sure the symptoms point at a slightly dodgy steering wheel sensor which has now completely failed.
Two questions:
1) Has anyone removed or replaced this sensor before ? Is it hard to get to ? Do I have to disconnect and remove the air bag to get at it ? I presume so, and its not something I'm looking forward to. is it likely to be repairable or should I be getting hold of a new one first ? Any clues as to where the cable runs and where the plug connecting it is ?
2) I wonder how many other people have this problem ? Could it be a contributor to some peoples mysterious hard ride ? Below 25Km/hr and including during a manual bounce test the car would be in soft, but as soon as you exceed that speed you're stuck in hard mode.
I only initially noticed it because I have an LED permanently connected.
GRRR.....
Regards,
Simon
