Fair comment - I haven't listed my Xantias FULL description.
It's a very early L plated '93 VSX 1.9TD without AC. I wouldn't mind,
but I didn't bother stripping down an identical cars dash just a week back
that was all 100% working!
I'm guessing the whole mechanism is cable operated with the car being
so early in spec VSX - trim notwithstanding. The other issue I have, is the
car isn't near me at the moment as a good pal is using it until his 25TD Xm
gets back from some fettling surgery/expense on it's timing belts etc.
Jut come off the phone now and he's saying the wtare temp went high
to 100 or thereabouts and he's letting it cool down before checking water
levels etc. I hope the HG is OK although it should be as the engine has in
the recent past had a anew head with HG etc at significant expense and
it usually as good as gold. It would start acting up when it's not on my watch...
Guess the lack of heat and the heating up of the engine are too much of
a coincidence to ignore. My pal is pretty clued up on the mechanicals so
I've told him to check/bleed/top where necessary on the cooling circuit
and report back although it looks like I'm going to have to go and look
at it, for my peace of mind - can't have one of the regulars pack in on me!!
Andrew
