Hope those more knowlegeable and experienced than me can help here.
Is the 1994 Xantia TD high pressure pump repairable.I've looked through some previous post but cant find anything.
I believe my pump is the early type,6 piston with 2 connections only.I say this because it appears to be weeping LHM fluid and I've checked the renowned black hose connection at the pump for leaks and security and it seems fine to me.
If the pump is serviceable,what sort of job is it to do and are the spares readily available.Iknow I have the option of a second hand one from the breakers,but again what condition is that going to be in?A new pump is out of the question right now as I'm not flushed with the queens notes.
Anyway any help here would be greatfully taken.
Thanks in advance Steve
