Is it possible?
When my sat nav is showing me as doing 60mph, my 2.1TD's speedo is saying 70.
Is there anyway to improve accuracy at that end?
I've never had a car so far out before.
Increasing speedo accuracy
Xaccers
- x 186
DIY sphere tool
DIY sphere tool
- x 1459
I don't know what happened to the later electronic speedos - my 95 TD was pretty close, and my wife's 94 ZX (Cable) is pretty well spot on. My 97 TD is wildy optimistic though - much the same as yours (maybe this is why people get 50mpg out of a 1.9TD Xantia - they are driving at 50mph indicated, but it's actually about 42 or something)! I just ignore the speedo and drive off the rev counter, where gears 1 - 5 = 10,20,30,40,50 mph at 2000 rpm pretty well spot on - and 3000 rpm = 75mph, which is easy to follow on the motorway, as it's needle sticking straight up - I think the ML5 box is longer geared though, so might not be so easy! In theory I guess you could get it recalibrated, depends on whether you can change the programming of the PCB or not. Or get Jim to build an attenuator to change the signal output
AndersDK
elma
- x 287
tricky ricky
lolingram
- RIP 2010
It is not only possible, but spot on. What wheels/tyres are you running on?
Is it possible?
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
Stempy
Don't know about the Xantia speedo but I did a lot of experimenting with an electronic speedo from a BMW motorcycle which was wildly optimistic and found that it was possible to recalibrate it by adding and removing the jumper links on the pcb. These links were obviously for calibration purposes and grounded out a number of pins on the drive chip. I got it spot on by trial and error, maybe I happened upon 'police spec' settings.
Lexia ponce
Lexia ponce
lolingram
- RIP 2010
A speedo can overread your true speed by up to 10% but cannot under read it. So if your speedo is indicating exactly 30mph your true speed can be anything from a shade over 27mph up to 30mph. Conversely if you are doing a true 30mph your speedo can legally indicate anything between 30 and 33mph.
There is no current EU legislation that insists on speedos being +10%! SatNAVs will give TRUE instantaneous speeds with a sample rate of around 5 seconds...
The gps isn't necessalary accurate either. Mine says I'm doing 85mph for 2 hours to do a 200mile journey. It can only be correct if you travel at a constant speed in a straight line.
The car speedo must be 5mph high because of eu legislation.
Previously...
Previously...
Xaccers
- x 186
205/60 on Activa alloys.lolingram wrote:It is not only possible, but spot on. What wheels/tyres are you running on?
DIY sphere tool
DIY sphere tool
