Managed to remove the instrument cluster by undoing all its screws, lowering the steering wheel to max low position taking the top cover off the steering wheel consul, then the pulling the cover forward, unplugging all the side switches.. Finally tilted the whole thing upward and undid the speedo cable
.. it was then possible to rest it on the dash top upside down and facing foreward.
Took the cover off the rev counter, and tightened up all-any screws and connections in sight, started it up, and it worked.. Put it all back together again and it seems fine now
Thanks for all the help.
( it took about an hour and a half max
James. (Nr M67 East of Manchester).
Dark Blue ZX 1.9D Auto 1994 'L' 5 dr (modified) Aura. 98K miles used daily. Ave mpg 40
Wedgewood Blue 75 CTD auto Connoissaur. 2002. 144k. used daily. ave mpg 40 ish.
