Rear windows
xantiaholic
Rear windows
Hi does anybody know about the rear windows electrics, the rear windows switches both on centre console, and on the doors do not light up nor work, have checked the fuse this is ok, I take the relay powers both front and back? the switch on the dash board may be the next part that may not be working the way it should, it does light up but thats about it. any body have any leads, xantia 2.0 ltr hdi 1999 on a T reg. Regards Mark
mezuk04a
AndersDK
There is a separate power relay and fuse for front and rear EW's.
Possibly exactly the rear circuit relay has partly left its socket leaving the circuit dead. Just need a thumb to press in.
Or the relay has given up the ghost. Its a standard single make contact relay type at some £3-
If you lift up to test the relays from their sockets, you will immediately recognise by the pinning any other relays of the same type. These are legitimate to swap for testing purpose. But keep track of where the relays belongs (usually by casing color). They have slightly different specs in current ratings, pin outs and functions.
Citroen (e.g. PSA) do their own relay case coloring codes for the relay types. You dont strictly need a relay "the same color", if you know the relay type.
Anders (DK) - '90 BX16Image
xantiaholic
No joy, I have changed around the relays but still no power to either back windows, the switches do not light up on centre console or on doors, the only switch the one on the dash board will light up and make the relay click, but makes no differance on the window operation. Anybody have any other ideas. regards Mark
mezuk04a
xantiaholic
mezuk04a
Im afraid I can only give info on the Mk1's so to speak, where the rear windows switch was placed behind the handbrake area.
For my rear ones (at the handbrake) I simply took them out (flat electrical screwdriver) and picked out any grime/crud and sprayed with some wd40.
Replaced the switch and nearly two years on its still fine.
Golf 55' 1.9TD
xantiaholic
mezuk04a
xantiaholic
