Sorry for the 3 in 1 post, felt it to be better doing it this way than to look selfish starting 3 threads one after another. Here goes:
1. As the title suggests, my drivers side back door is stuck close, both from the inside and out, it unlocks ok, well the 'thing' pops up.
Only clue I have to the problem is that it's ok if I park at angle (upwards towards a hill).
I haven't checked the child lock, could this be half way open/close, or is there something more obvious some you lot have come across.
2. On top of this, I noticed with the recent rain that I have a leak. I don't have a sunroof, so my first guess is the aerial in the top. The water enters the car through the drivers sun visor hinge (the left/centre one).
This would probably explain why I get a bad signal on my FM radio.
Is it easily fixed, I don't want to yank the aerial base off only to find out that the seal gets worse, or I've bent the body work more in that area. I don't think it's coming from the windscreens top seal.
3. I have a concern
Thanks in advance.
