The problem is that the brakes are juddering but not in the usual way. On reasonably normal application they judder and this judder can be quite distinctly felt through the pedal, almost as if the ABS is coming in but it's not regular like if it was ABS. It is best described as a rough, uneven judder, the sort you'd get if the discs were really, really rough and uneven. Like if they were really badly rusty after being unused for years.
So, I put new pads in and checked the front discs. Nice and shiny and as far as I can see, not distorted although I have not checked them for run-out with a DTI. I bled all four brakes but only got a little air out of one rear.
It has improved it but not by much. I'm thinking it may be hydraulic in origin as there are other symptoms that point to weaknesses in the hydraulics.
The regulator tick rate has got shorter recently. In fact it never ticks (never has in my ownership) but hisses for a while and they does not hiss. This hiss followed by no hiss is occurring about every 15 seconds now.
The car drops very rapidly when it is stopped, it will sink fully in 15 or 20 minutes and starts to sink almost immediately it is switched off. Perviously it would stay up for a good hour. This car is an early non-antisink model.
It is not the accumulator as I swapped this recently trying to chase this short hissing cycling. In fact Xac is running the old one on his 2.1. On initial strart the STOP light goes out quickly and the car rises very rapidly. Each corner is nice and soft and doing citarobics the speed from low to high and down again is really quite rapid.
The Brake Doseur makes a squelchy hissing sound when the brakes are applied but does not appear to be leaking. The ABS is working normally (in that the lamp behaves normally) and there is no loss of LHM anywhere. I did notice that the regulator went into a long hiss when I was bleeding the brakes as if the system was having trouble keeping up with the pressure demand and this I think is why the brakes feel so strange, the system is unable to keep up with the pressure demand but having said that, the suspension does not drop noticeably under braking and nor does the feel of the power steering change.
Am I looking for a complex problem here when it's just slightly warped discs? Grateful any thoughts on this one. Its got me
