On my Xantia as i turn left and the weight shifts to the right hand side of the car I seem to have some instabillity. Also the drivers side rear where the weight shifts has an odd wear pattern mostly around the outside edge.The pressures are all fine that was my first check.
Also the fronts are wearing around the outside edges is this just tracking?
Thanks for your help.
gav425
Xantia Tyre Problem
PicassoPigeon
Xantia Tyre Problem
2002 Citroen Xsara Picasso 2.0HDi
125,000 miles
125,000 miles
- x 1240
If both outside edges of the front tyres are wearing evenly then thats fairly normal, especially if you corner fast, wear on the outside edges would indicate to much toe in and vice versa. Any uneven wear pattern that varies around the circumferance is usually down to a defective tyre, but excessive wear on the inside edges of the rear tyres is generally down to the radius arm bearings having failed
jeremy
If the toe in is significantly out you will probably be able to see it if you look carefully - for example with the wheel straight ahead - sight along the tyre edge and look at the back wheel. - If you find both sides that you are looking at something far outside the line of the back wheel - then you have considerably excessive toe in. This is NOT an accurate method of tracking - just MAY give you an idea of what is wrong.
Instability on weight transference sounds more like bottom ball joint or wishbone rubbers.
jeremy
