engine mounts
metgreentd
engine mounts
Unread post by metgreentd »
anybody know if the engine mount nearest the cam belt is the same on a xantia td xud as on the bx td i have been in touch with gsf and they only list a bx one but they thought they were the same but wernt positive thanks
x 8080
According to pr.net they are significantly different :(
They normally don't seem to give much bother. I'd see if I could get one from a scrapper as they are quite expensive from Citroen.
x 94
Unread post by citronut »
the one i know to be the same is the lower stabalizer bush which GSF call the lower mount
regards malcolm
AndersDK
Unread post by AndersDK »
Is it the metallic bridge or the rubber carrier on the inner wing you need ?
Anders (DK) - '90 BX16Image
metgreentd
engine mounts
im presuming its the rubber i want.when starting or stopping the engine it leaps about giving the car a good ole shake its fine at all other times thanks
x 94
that sounds like the lower staberlizer bush to me
regards malcolm
