http://www.frenchcarforum.co.uk/forum/v ... hp?t=22130
Dei asked what the benefits of using Hydraflush were.
Dei, I'm now in a better position to answer after draining my old LHM and refilling with hydraflush today.
When I bought my Activa, I had a look in the LHM reservoir and noted nice green LHM. It had a new HP pump fitted a short while before I bought it and given that nice green LHM that came out of the bleed nipples when I first bled the brakes I thought all was well in the hydraulic department. I was fooled
I suspected that all was not well when I'd had it a few days but lots of citarobics and new spheres all round and a brake bleed seemed to make things better.
Today I pulled out the filter block on top of the LHM reservoir in preparation to syphon out the old LHM and got the shock of my life. The filters were so badly clogged they were almost invisible. They should be off-white with a fine gauze in them but both mine were a uniform black and each wearing a fur coat
It took me an hour to gently clean them in petrol and to clean the LHM reservoir. It had a deposit of the same muck on its base about a mm thick.
Now, however good you are, when you clean, there is no way you can clean out all the nooks and crannies in the filters and reservoir so it has to be a good idea to run Hydraflush if only to give these items a clean. If that was the state of the reservior and filters, the state of the rest of the system does not bear thinking about
After refilling with Hydraflush and doing a good bout of citarobics and bleeding the brakes the differences became apparant. After only a short time in the hydraulics began working much better. Firstly I noticed how much faster the car rose and fell. It had always been very sluggish in the past.
Out on the road it seems smoother and more like a Xantia should be. Althhough you'll never get a magic carpet ride from an Activa, it is subjectively better and I hope as the Hydraflush works its magic over time it will get better. Even the brakes feel better.
The STOP light also goes out a good deal faster now as well.
All in all a good afternoons work, punctuated by a massive thunderstorm whilst I was safely tucked inside the garage cleaning filters!
I'll leave the Hydraflush in for a 1000 miles and then refill with LHM. I'll be cleaning the filters again too
Just one question. Where does all this muck and dirt come from in what is effectively a sealed system? There did seem an awful lot of it.
A few tips I picked up: The Filter block will not come out of the reservoir unless every pipe is pulled off. I was spoilt on the old TD as the block would easily rise up without disconnecting any pipes at all so I was wrong in what I said in another thread on changing LHM
The pipes will drip for ages when disconnected. As soon as you pull the reservior out, put a suitable drip tray under the pipes if you don't want your gearbox and driveway covered in LHM
The original clips can be re-used with care. Prise them open gently with a very small screwdriver using a twisting motion. Use a small pair of needle nosed pliers to re-clip them. It is easiest to get one side hooked on first and then it'll snap shut.
Petrol is a fantastic cleaner for the filters and the reservior. Take care using it though and use it out of doors!
Those mesh filters are very effective. Despite all the muck and sediment, the LHM I filtered out was crystal clear and clean, if not a little on the yellow side.
LHM does not taste very nice. I need to use something other than Jim Suck Power on my syphon when I come to drain the Hydraflush
I hope it's not toxic
And I still swear at the front caliper bleed nipples. What a silly place to put them
