Gear selection is generally OK but often it's a bit "baulky" going into third on down-changes, accompanied by a gentle crunch, particularly if I'm being a bit enthusiastic
After the rod operated BE3 gearchange, I've often felt the ML5 is a rather "sloppy" in comparason.
I don't think the synchro is at fault because double-declutching does not help and I'm used to doing this on my GTi
Grateful for opinions on the quality of the gearchange I should expect and any checks/adjustments to the cables I may be able to make to improve matters.
Thanks!
