Lads,
My van failed the MOT on the new smoke emmission test....bummer! Anyone else had this or know possible causes....valves, tired engine??Going to take it to a garage or two but would like to be a bit forewarned.
thanks in advance
Rob
partner van fails mot on smoke emmissions
philhoward
robzondrumz
504GLD
I agree, a good italian decoke, take it out for a run let it get hot, then drive it hard in 2nd gear until the rev limitor kicks in, drop off the revs a bit, and back on, pumping it on off I find works best until the exhaust is nice and clear.
Make sure the air cleaner is good, and of course change the engine oil they both help lots.
AndersDK
- x 8444
Brian UK
amjake
I posted a note on Ametech Restore oil a while back and got to say I'm very pleased with the results so far, quiter running, boost in power and still 45mpg!
http://www.frenchcarforum.co.uk/forum/v ... hp?t=21816
Many testify to reductions in smoke emmissons too might be worth a can prior to MOT or injector clean/italian tune up.
kev
kev
robzondrumz
504GLD
amjake
504gld, In response to your insinuation, I have nothing to do with ametech only as a user of the product."amjake" am = amtech by any chance? using an oil additive will hide or mask a problem not fix it, making it worse in the long run I reckon!
( amjake = acronym of my full name ie. ke=kev, am=mark, etc!!! Administrators can verify!)
If you read my post on the additive then a car on 200k + fsh with no problems other than being an 'old girl'. If the stuff makes as big a difference as it has then its worth a try rather than spend big money on uneconomical rebuilds etc. considering the age, mileage and value of the car.
IMHO, It's the same as running with millers/redex/stp to keep injectors clean or greased lightening/Slick 50 to stop engine wear etc.
If it was dodgy/dangerous then I am sure we'd hear about it like we did when Shell introduced Formula Shell and the recent problems Tesco's had with their additions to their range of fuel!!! As I said his ebay record speaks for itself and then there's always trading standards if it doesn't do the job claimed.
In all fairness I think your statement also relates to the suggestions of an 'Italian Decoke' we've all done it for the MOT but as you stated 'it only hides or masks a problem not fix it etc.'
My corner has been defended
Kevin
