Wiring diagrams
x 1430
Wiring diagrams
Has anybody had a go with the wiring diags on citroen-service yet? Any good? Or, has anybody got a Haynes for the ZX that's later then 93 (I've got the original 92-93 book)?
We've got a slight niggle with the head lights on our 94 ZX TD - sometimes when you switch them on you don't get full dip, it stays on dim dip, only giving dip when you operate the switch to main beam. My wiring diagram says the dip is fed straight off the switch, but this has got sticking relay written all over it. I replaced the column switch last year (new, gen Valeo jobbie from GSF), so can't believe it's that - although it did seem to improve for a while afterwards :roll:
Hopefully it will play ball when the MOT man turns the lights on.....
jeremy
Unread post by jeremy »
You can download a Haynes petrol manual here:
I have a 94 one and think there were some electrical changes around 93 or 94 as the fuses on mine are not the same as listed by Haynes in my diesl manual which pre-dates the car.
http://citroeny.cz/servis/servis.htm
jeremy
AndersDK
Unread post by AndersDK »
Anders (DK) - '90 BX16Image
