Every few minutes the indicator relay starts clicking very rapidly even without moving the stork to indicate.
I replaced the relay with a spare and exactly the same thing happens.
Could it be the contacts on the stork or dodgy wiring that is causing this
Xantia indicator relay
lolingram
- RIP 2010
I have had this occur on several PSA vehicles; intermittent and then goes away. Never resolved the problem, but I feel it is wiring/switching related.
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
- x 8119
Although it has so far not happened to me, I understand this is a very common problem and is caused by the stalk itself.
There have been several other posts in the past dealing with this:
Try this one for starters:
http://www.frenchcarforum.co.uk/forum/v ... ator+click
And then this one:
Hope this helps...
And then this one:
Hope this helps...
- x 1436
Yep, it's the indicator switch causing it. You should find it will stop if you wiggle the switch up and down. If you're lucky you might also get a burning smell and some wisps of smoke out of the switch
I replaced the swtich on mine the other week because it jammed eventually. I took the old one apart (pretty easy to carefully spring the clips and lift the top off) - the indicators are operated by pin running between 2 tracks. There was quite a lot of evidence of burning around the tracks, and they were filled with gunk - I guess the switch partially makes, then when the relay tries to pull in there isn't enough current to support it, so it drops out again, when there is enough current to pull it in again...ad naseum
. You might be able to clean the tracks / pin up enough to stop it clicking. Getting the swtich out is not too bad - need to remove the steering wheel, but that's easy enough actually (the most difficult part was removing the cable connector to the PCB for the steering controls - you need to lift up the pin in the clip). Don't forget to leave the nut on the end of the shaft whilst you jar the wheel off the splines - otherwise it can wreck the air bag cables, and biff you on the chin! Getting the column shrouds back on is a bit trying though
