ECU fault code 22
MikeT
- x 232
ECU fault code 22
Does anyone know what code "22 - Security Relay" indicates? I know my alarm is self-triggering after several minutes of me setting it so there is obviously a fault. Thanks
jmd
Try the following website it basically deals with Peugeot, but since the engines are cousins - if not more closely related , it may be a help. http://www.pikit.co.uk/peugeotmt/eobd%20p%20codes.html
AndersDK
MikeT
- x 232
jmd, that's a very informative site, thanks! However, since speaking to the mechanic that pulled that code from my car, I've learnt it's not a "P" code, but he thinks it came from my ABS ECU, he couldn't remember. I thought it may have come from my alarm ECU as it clearly stated the fault code is related to a "Security Relay".
MikeT
- x 232
http://www.pikit.co.uk/peugeotmt/psa%20 ... codes.html says these are the PSA EOBD codes from Peugot/Citroen so I don't see why a particular model should be excludedAndersDK wrote:Does a '98 Xantia turboDIESEL have the EOBD code system ?
AndersDK
Mike -MikeT wrote:http://www.pikit.co.uk/peugeotmt/psa%20 ... codes.html says these are the PSA EOBD codes from Peugot/Citroen so I don't see why a particular model should be excludedAndersDK wrote:Does a '98 Xantia turboDIESEL have the EOBD code system ?
Thats not the question.
I was wondering if the system with these codes were incorporated - at all - in a '98 diesel car.
I donno from which build year the EOBD codes were incorporated, but its certainly close around buildyear 1998 on.
To my knowledge the EOBD codes are valid for multiplexed cars only.
Anders (DK) - '90 BX16Image
jmd
MikeT
- x 232
