Swings and roundabouts really. The estate is newer, more economical and more practical than the Activa, however it's not as fun to drive and has virtually done 3 times as many miles as the Activa had done. On the bright side however, it's my brother that now has it, so it's not entirely out of my reach
The reason I'm posting this, is that there are a few niggles with the estate. Nothing what you'd call major or catastrophic, but niggles to me all the same. I'm hoping that by posting them up here I can get a bit of help sorting them out, as I know how friendly and helpful you guys are!
The estate was previously a taxi, and has done 190,000 miles. I have virtually NO service history with the car. I'm just glad that I didn't pay much for it! Overall it's a pretty tidy car, the engine is only a little noisy, but pretty good for 190k! It pulls well and doesn't smoke etc.
So, on with the problems!:
1. Left hand cooling fan working all of the time and the Bitron Unit isn't mounted where it should be, but shoved in behind the headlight. Leading me to believe that there is/was a problem with this.
2. Air con not working, but this is going to a specialist to sort.
3. Gear change is a bit sloppy - it will go into gear OK, just not particularly "nicely". I'm wondering whether this is the linkage being worn or the gearbox worn - or a combination of the two.
4. Engine cut out on over run. This happened to me today, but after I was gunning it a little. It cut out, but only for a fraction of a second. When driving normally, was no problems. I'm thinking that maybe a plug and lead change may sort this?
5. General sloppy feel to the car/suspension. I guess this is probably down to worn bushes etc on the suspension components. I'm considering breaking up my 1.9D to get good parts and spares for the estate, then putting these on. Probably more economical than MOTing the 1.9D, selling it and then buying spares anyway.
I think thats about it for the minute. Nothing too major, but niggly nonetheless.
Any thoughts on the above would be appreciated. My first priority at the moment is getting the aircon/cooling fan situation sorted, then going from there. Eventually I would like to replace the engine, but only after doing the rest of the car first!
