Xantia rear seatbelts not exchangeable
JohnCKL
Unread post by JohnCKL »
I guess few would do this, swap the Xantia rear seatbelts left and right. I did it cos there are some sound behind on the left side which I thought might be from the left rear seatbelt. After the swap, the sound is still there and the seatbelts can't be pulled out. I readjusted them a few times but they still can't be pulled out smoothly. Only when I swap them back to the original positions that they can be pulled out smoothly. When taken out, they look just the same, no indication of left or right, only different serial numbers. I bet no one knew this.
Xantia 1.9TD 1996
dnsey
x 19
Unread post by dnsey »
All inertia reel belts have a corect mounting angle, and won't work properly if they are fitted any other way.
