Water drawn into diesel engine
LeeDJC
Unread post by LeeDJC »
Hi all, just a bit of advice needed really.
I have seen a clio van locally, but it has been driven through a deep puddle and drawn water into the engine, and now won't start.
I haven't seen the van itself, and don't know any more than this, but what I want to know is....
Is this likely to be terminal? Is is possible to get the water out if not - towing in 4th/5th perhaps? If it's likely to have done any damage - what sort?
Thanks!
Lee
2004 Berlingo Multispace HDI, 105000
Xaccers
x 188
Unread post by Xaccers »
Similar thing happened to my 95 Xantia 1.9TD (who was the wise guy who put the air intake down behind the front passenger fog light???)
All I did was remove all the intake hoses, and the injectors (sent them for a clean, replaced the battery, drained the intercooler, and turned her over until the injector sockets stopped puffing water.
Put everything back together and she ran fine (but then, it was a XUD) for 6 months until my "lovely" neighbours torched her :(
DIY sphere tool
LeeDJC
It's an ebay listing thats only down the road from me, and he reckons he was told it may need a new head. Seemed a bit extreme to me.
I thought water in the engine just meant a loss of combustion.....
Xaccers
x 188
the water will go in via the air intake, so the piston will try and compress water rather than air/diesel mix.
If they hit the water at high revs, it could have caused head damage.
You really need to drain it and do a compression test to be sure.
I was only doing about 20mph and lifted my foot off the gas when I hit the puddle which was a lot deeper than it looked!
DIY sphere tool
reblack68
Unread post by reblack68 »
Liquids can't be compressed and the engine may well have destroyed itself trying. As well as head damage it might even have bent a conrod or damaged the crank. I would imagine the seller has tried all the easy options to get it running again.
If you've ever belly-flopped into a swimming pool you'll know how unyielding water can be.
You might be lucky but only buy this van if you're prepared to replace the engine.
Richard
Care of a 1994 205 D.
np
Unread post by np »
My sisters boyfriend killed her Clio diesel a few mths ago going through a very deep flooded ford.Locked the engine up & smashed the head up as the water entered the pistons.
Then again it all depends on how fast & how much water got in.
53`406 est SE Hdi 140,110k
AndersDK
Unread post by AndersDK »
If you are lucky the water is expelled rather instantly by the valve's own standard timing.
On a diesel there really aint any combustion chamber left with the piston at TDC. Just barely a clearance from piston head to the cylinder head & valves surface.
A few milli liters of any liquid in a diesel engine cylinder will instantly deadlock the piston at near BTDC. Because liquids do not compress it will work like a rock solid material, blocking the piston.
Depending on materials, tolerances & forces involved (i.e. rpm) this means either :
1) bent conrod
2) snapped conrod
3) cracked piston head (perforated)
4) snapped crankaxle
5) injectors damaged by reverse pressure from the water
Even a multiple of the above.
The cylinder head & valves would rarely be damaged, as the closed valve heads are by far the most durable members of the party here ...
TBH Lee, you dont have time for such a project. Dont touch it :roll:
Anders (DK) - '90 BX16Image
LeeDJC
Hmm, sound like a def engine replacement then.
The reason I was thinking of it was to replace the rather shabby clio van that my parents have. The engine is goo, but the rest of the van, frankly, is not!
ACTIVE8
x 6
...How Much H20 & Where's It Gone !
Unread post by ACTIVE8 »
Yes as a donor body/chassis to use their engine it could be worth it, but obviously the swapping of components will take time. I agree with the others about the hydraulic problem with the other engine, it will be a lot of work, so therefore the engine swop would be the best option.
philhoward
Unread post by philhoward »
I'd assume the engine is beyond salvation - if it won't start, then someone has tried..and probably finished the engine off. Probably as much use as a boat anchor now...
The carnage could be slight or terminal - at least a head gasket. At worst, snapped camshaft (it can happen), bent conrods - i've seen a few banana shaped ones...the list goes on.
