It has a problem that is really spoiling my enjoyment of the car and is driving me nuts. When I got it the brakes juddered badly and lacked stopping power. I thought it was just sh*gged discs and pads, no problems. So I fitted some sh*tty Ha*fords discs and pads (I know, I know but it was convenient...). It was immediately apparent that the brakes still juddered. After 150-200mi bedding in the brakes behaved like this:- Stopping power was as good as I'd expect, braking from high speed (70-80mph) there was good bite and no vibration but as i slow there is a vibration which rattles the car, can be felt through the pedal slightly and totally spoils the feel of the brakes, also doesn't seem to be quite the bite and easy stopping power I'd expect from low speed. A passenger in the car would be able to hear and 'feel' the vibration. I thought it was just the poor quality halfords discs as although there was judder as before it was nowhere near as pronounced and the brakes were a lot more powerful. So I bought some Brembo discs from Andyspares and fitted them. When I fitted them I ensured the hub was scrupulously clean and flat and disc mating face clean etc, retaining screws in place, calipers on and bolts torqued up, copper grease on backs of pads etc. But surprise surprise the vibration is still there, the brakes feel sh*t. The stopping power is there but at low speed (<50mph) there is still pronounced vibration through the car, pedal, car doesn't feel like it's biting and stopping like it should.
I don't know what it could be! With the wheels off I can say that there was no detectable play in wheel bearings/hubs, drop links for anti roll bar fine, track rod ends look spot on, no visible play in suspension, gave a tug here and there all seems fine. Tyres correct pressures, wheels not been balanced but the balance must be fine because there is no vibration through steering at any speed from 1mph to 110mph under acceleration of deceleration. The car drives in a perfect straight line at any speed, doesn't pull either way, tyres worn evenly, also under braking light or heavy the car pulls up in a perfect straight line implying that the calipers are fine (no leaks etc seem to slide fine).
I haven't checked the back brakes yet (drums). Could they cause this kind of behaviour by out of round drums etc?
It is really doing my head in so any ideas of what to check etc would be gratefully appreciated. I'm determined to get to the bottom of this if I have to replace everything-it's really wrecking this car for me.
Cheers
Guru Meditation
