Hi All,
I am going to France in a couple of months and need to make the headlights on my MkII Xantia legal for driving over there.
Anyone got ideas on what part of the headlights need covering??
Paul
Xantia Beam Benders
wrinklet1
Xantia Beam Benders
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
- x 8058
Good job it's not a MK1
I tried in vain to make beam deflectors work on mine
On a MKII I believe you put the beam deflector edge up against the spot cast into the middle of the lens on the dip side with the beam deflector running to the edge of the lens (toward the indicator lens).
There are two spots cast into the glass and the dip side is the one with the lines on it. The main beam side is mostly clear glass.
jeremy
You're lucky they are bright enough to worry about!
There are some diagrams in the MOT testers handbook which may help
http://www.motuk.co.uk/welcome.htm
On some headilghts you can see the pattern of prisms and lenses that produces the raised beam on the left (facing forward) I think its normally below the centre line to the off side of the light unit and probably triangular. Covering this with black tape should prevent the raised section of the beam.
jeremy
JohnD
- x 72
Maybe you can see the beam benders I used when I had my Xantia. They are home made from black plastic but copied from a Lucas kit. I used them for a lot of years taking the car abroad twice a year. They cut down a lot of available light, but they really do work.
Sorry!!!!!!!!!! Can't get the picture - what have I done wrong?
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
JohnD
- x 72
- x 1238
- x 94
hold a piece of black board in front of each headlight with them on dipped beam (one at a time) you will see the kick up in the pattern, just stick insulatting tape in a triangular shape on the glass till you just delete the kick up only,so the beam pattern is a flat line,it is only the kick up in the pattern which hits on comming driver in the eyes whilst you are driving on the wrong side of the road
regards malcolm
regards malcolm
