My 405 has failed on a broken rear brake compensator spring. Would anyone know if I can get just the spring from somewhere or what other models have one fitted that may fit?
Thanks.
Steve.
405 Brake Compensator Spring
steelcityuk
not applicable
504GLD
matt
Last time i tried to get the part from the dealer they only sold the whole compensator,gsf had the same answer too.
Ended up just welding a new hook on the end of the spring!
i was amazed it worked too.
I dont know of any other psa group vehicle that shares this spring(which is rare) So might be a case of the scappy
Have fun
Have fun
92 205 1.9 GTI(MODIFIED,SORRY )
1996 VOLVO 850 2.5 5CYL 10V
1999 EXPERT VAN TD - WHITE !
No more car's thanks!
AndersDK
I would not recommand welding on steel used for springs.
Instead some brains on what the spring is there for ?
Does the springforce in ANY way influence the function of the brake limiter ?
If not there are 1000's of possibilities to source a new spring.
The way I remember these brake limiters from my time before Citroens, is that the spring is used as a simple flexible rod to transfer the position of the rear ARB to the limiter valve.
Please dont hesitate to correct me if I'm wrong.
Anders (DK) - '90 BX16Image
matt
I wouldnt normally weld spring steel either when the mot is round the corner i didnt have much choice!AndersDK wrote:I would not recommand welding on steel used for springs.
I think the spring acts as a buffer?One end is a threaded rod that screws through the compensater the other end is hooked over the trailing arm.The more weight on the rear of the car,the more brake pressure is sent to the rear drums.So if the compensater is variable(which it most likely is)the spring rate will have an effect on the rear brakes,so it may be difficult to find another the same spec with the threaded rod aswell.
Dont you just love pugs eh
caveman_si
Find a similiar shape, size and strength spring and replace it.
I had this issue a few yrs ago on my old 405. And was told by everyone the only thing to do was replace the unit as one. A lot of money for what is a 5p spring.
I found a spring of almost simialr shape, size and strength and replaced. Was a little fiddly to replace, but on the retest everything was fine and both sides were exactly equal in breaking.
The hard part is finding a similar spring.
406 lx 1.9td estate
fastandfurryous
- x 4
steelcityuk
After scouring the scrapyard I hadn't found anything similar on the cars so I grabbed a selection of springs from other parts of the vehicles. I managed to get a indicator retaining spring to fit, it's just about the right length and the large hoop can be unfastened then threaded through the brake compensator lever. It seems to work OK and the car passed it's test.
Thanks for the suggestions.
Steve.
Steve.
not applicable
matt
