Xantia brakes
Joe Pineapples
Xantia brakes
Hi folks. Does anyone know where (or if) I can get a hold of the anti-rattle shims from the front brake calipers on a Xantia (1997 TD)?
Cheers.
Cheers.
'02 C5 HDi LX
'00 Xsara HDi SX (For Sale)
'97 Xantia Temptation TD (RIP)
'00 Kawasaki ZX6-R
'71 Girlfriend
'00 Kawasaki ZX6-R
'71 Girlfriend
Xaccers
- x 185
I think Halfords do them, or used to.
Never had the need of them myself.
DIY sphere tool
DIY sphere tool
Joe Pineapples
- x 8089
I may be wrong but they don't have any! Usually the pads ahave a skim of copper grease on their backs and nothing more.Joe Pineapples wrote:I have a pair missing from the front drivers side and the pads rattle like buggery!
If they're rattling then you have a problem elseware. I'd say the handbrake adjustment mechanism was not working correctly or they're not assembled properly.
Essentially, the pads are kept in very close contact with the discs by the ratchet action of the handbrake adjustment mechanism which takes up any play. Maybe this mechanism is broken through someone not realising that the piston needs to be wound (rotated) back when replacing pads and not simply pushed back as in the case of conventional calipers. Undue force in trying to retract the piston in the conventional manner will wreck the helical screw.
How well does the handbrake work?
Also, it may be the rears making a racket. It is easy to confuse where the sound is coming from!
Joe Pineapples
No, they are deffo missing. I only had one pair, they are in the nearside caliper. When you jack the car up, you can rattle the offside pair, but not the nearside pair, these wee clips hold them in place.
'02 C5 HDi LX
'00 Kawasaki ZX6-R
'71 Girlfriend
'00 Kawasaki ZX6-R
'71 Girlfriend
Xaccers
- x 185
Trying to remember the fronts, but the backs have a bent clip that holds the pads in place, like a square U shape.
When did you last bleed the brakes?
DIY sphere tool
DIY sphere tool
- x 8089
Oh yes, of course!!! I was thinking of the old style anti-squeal shims that go between the pads and pistons.
Sorry.
You mean the big springy bits at the front
As Xac says, Halfrauds may have them but they don't normally need replacing. Failing that, a scrap yard. A dealer will do them but I'll wager they'll be pricey!
Xaccers
- x 185
I thought Joe was refering to those too.citrojim wrote:Oh yes, of course!!! I was thinking of the old style anti-squeal shims that go between the pads and pistons.![]()
Sorry.
My rear pads have them, but I've never seen a Xantia with them on the front.
So the only thing I could think of which stops the pads rattling (other than as you said, the piston itself) is the springy clip thing.
DIY sphere tool
DIY sphere tool
Joe Pineapples
Xaccers
- x 185
Blimey! They really are living up to their stealer's name!Joe Pineapples wrote:The springy clip things! That's the buggers! From a dealer - £30!!
Try going round to a scrappy, especially ones that let you take things off the cars yourself, as they'll probably let you have one for free.
DIY sphere tool
DIY sphere tool
Joe Pineapples
Xaccers
- x 185
Said the assassin droid to the dealerJoe Pineapples wrote:Yeah, I was kind of expecting that the scrappy was my best option. Time to get my hands dirty.
DIY sphere tool
DIY sphere tool
jeremy
AndersDK
- x 94
