I have year 2000 synergie, hdi. How do I set the tension in the auxiliary belt.
thanks
synergie hdi auxiliary belt
- x 8068
Welcome to the forum!
I don't know the Synergie but I would have thought the belt would be self-tensioning via the conventional spring-loaded tensioner arrangement, hence the tension should set automatically.
Why do you ask? If you are trying to either remove or fit a belt, the tension is usually released by putting a 3/8" square drive into the hole for the purpose on the tensioner frame and leaning on it hard to compress down the spring whilst you slip the belt on or off.
toofargone
