Hi All,
I have got a 2002 Peugeot 406 2.0HDi rapier. The problem i have got is that the drivers side electric window no longer works it happened when i wound the window completely down and it wouldn't come back up. I can hear the motor working when the switch is pressed but the window doesn't respond. Does anybody know why this is happening/how easy it is to fix/how much it is likely to cost to get repaired.
Many thanks
406 Electric window problem
1993 Xantia 1.9TD (Died)
1990 BX 17TZD Turbo
Peugot 406 HDi
1990 BX 17TZD Turbo
Peugot 406 HDi
If the motor is still working when you press the switch the window could have come off winder.
Ive only taken a 405 door apart but it wasnt that hard. Be worth having a look yourself. If it is off the winder mechanism just a case of putting back on testing to find out if some has fallen off the should stop it coming off and then reassembling. Get a haines and have a go. Even if you cant fix it you will have an idea of whats wrong.
406 lx 1.9td estate
Had a look last night at the window mechanism. Everything seems to be in place there appears to be a wire that runs in a loop through a white plastic thing (sorry don't know the technical term) that the motor is attached to. When i press the switch the motor starts but the wire doesn't move.
Does anyone know if there is something inside that grips the wire that may have sheared or will i have to replace the whole motor and plastic thing.
1990 BX 17TZD Turbo
Peugot 406 HDi
1990 BX 17TZD Turbo
Peugot 406 HDi
had a look at the haynes manual not to clear regards windows but said it was unclear if you can buy motors or regulators separatly or if had to be purchsed together mabey a good second hand one would be the best bet .it also says the windows need to be programed if the battery is disc onected whith the window down .but if you can here the motor working it cant be that ? or could it if you want to try programing them ill type out the instructions .sorry cant be more help
IF I CAN HELP I WILL
- My Cars: not applicable
This is a wild guess but if it is anything like the system used on the XM then the wire rusts through and so the motor turns but nothing moves. If this is the case have a look here - http://cgi.ebay.co.uk/PEUGEOT-306-307-4 ... dZViewItem
Steve.
Steve.
not applicable
