Xantia 2.1td
Xantia 2.1td
Having looked under the bonnet of my 1997 Xantia 2.1td I was suprised to see that the engine, although not a HDi it differs to that of my previous 1.9td.
It does not appear to have the usual mechanical injector pump but the injectors themselves seem to be conventional (i.e. not the electro-mechanical items found on a HDi)
Is this engine a type of hybrid before hDi's came along?
Also, I would like to know the possibility of tuning the engine. There are a lot of companies that do re-maps for boost and fueling etc. Having looked on such websites the 2.1 does not appear to be catered for.
Is there anyone out there who can advise me.
Thanks in advance
Mike
Thanks in advance
Mike
'13 3008 1.6 HDi GripControl - x 996
The 2.1 fitted to the Xantia is a development of the old XUD indirect injection unit. It uses a mechanical injection pump (Lucas EPIC) which is electronically controlled. AFAIK it has a drive-by-wire throttle and this talks to an ECU which uses other engine sensors to talk to the injection pump to control injection timing and duration to meet throttle demands, whilst minimising fuel consumption and emissions. Or some such bollox marketing speak I believe it also has a turbo wastegate actuator.
Basically, there's more to go wrong, and as it's Lucas pump not a Bosch has 'limited' life span.
On the upside it is possible to re-map the ECU for 130+BHP - Superchips for sure used to do a chip so it should be possible to get it re-mapped. Might cost more than the car now though...!
- Xaccers
- x 184
£499 according to the superchips website.
Hmm...
Hmm...
DIY sphere tool
DIY sphere tool
Yes it does AndersDK. No idea which side has two valves, I think the turbo benefits from this design in some way. I wonder what the idea behind that would be. It's cooling system is also quite good compared to the other/older ones. I believe the 2.1 came with a fully mechanic pump too, as featured in the early XM.
They also have a hydraulic clutch too, and the gearchange linkage are links rather rather than wires, or something like that.
Yes, 12V - 1 inlet 2 Exhaust for each cylinder. Uses ML5 gearbox rather than BE3 fitted to the 1.9TD. This box has a cable operated gear shift and a hydraulic operated clutch (its still a pull type though!). Box is supposedly better, but the hydraulic clutch operating mech is a sealed system cosing >£400 and the cables only come as a set costing >£250 and a right PITA to fit. Progress. Apparaently
- Xaccers
- x 184
Bosch or Lucas?Peter.N. wrote:Yes, all my 2.1 td XMs have had purely mechanical fuel injection, even the two '96s I have now.
DIY sphere tool
DIY sphere tool
- Xaccers
- x 184
Don't suppose it's the same bosch IP as the 1.9TD uses?
DIY sphere tool
DIY sphere tool
