the air mixture flap on my air con has failed so it blows air at at any temp it feels like (which is a bit dispiriting in the summer)
i really cant face stripping the dashboard etc out to get at the flap and was trying to think of a another bodge
i am now considering the heater hoses running into the matrix if i disconnected them from the matrix obviously there would be no hot air
coming through my heating system at all
i was trying to work out a cunning way to do this so that i could still have hot air in the winter (not that we have much a winter here anymore) and i though of pollack valves
trouble is i cant find a website for them to see if they could cope with water at potentially very high temps
does anyone know the weblink for them (or have any other suggestions as to how i could do this
Cheers
aircon bodge
weety
aircon bodge
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
weety
i now appreciate they are called pollak valves
and have located a website.........
- x 1441
weety
it does but i have already changed the cabin temp control to no effect.....from the way the temp of the air changes as it comes into the cabin (from freezing to boiling almost instantly) the only thing i can think it can be is the internal mixer flap to set the temp which i think is just flapping backwards and forwards....
tempting as it is to remove the dashboard to try to get to it
i am now looking at any other bodges i can think of......
alan s
- RIP 2010
- x 6
weety
sorry mate its half midnight in england and i barely know what i am thinking
what are you hinting at?....and if it works i will e mail you loads of beer!!
alan s
- RIP 2010
- x 6
Clogzz
- x 40
The aircon control board is in the space above the passenger floor, high up towards the centre.
The map shows 4 wires going to the ‘moteur volet mixage’, hopefully for 2 polarities.
Story from Peugeotlogic:
http://www.peugeotlogic.com/workshop/ws ... atcont.htm
2002 C5 2.0i AL4 239,000 km 76372389
weety
if it span the wrong way round wouldnt the temp control just work backwards (ie hot on control = cold air)
does anyone know where the actual flap is that controls the air flow through from the heater matrix side (as it could be something as simple as a connecting rod (of some sort) that has become detached
alan s
- RIP 2010
- x 6
From my reading of it, I thought it might be the flap that had overstretched its limits and that if the polarity to the motor that drove it could be reversed, that tis would then close it. Being a "bodge" I reckoned if this were possible, it might be simpler to get to the wires than the actual flap, but going on Clogzz link, that may not becessarily be the case.
As I say, I don't know the set up so it may be way off the mark; just a suggestion.
Alan S
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
Clogzz
- x 40
The flap motor is visible and accessible from the passenger’s side, stuck against the carpet, at the very back of the centre console.
It’s got the metallic look as in the peugeotlogic link photo.
Faults show as hot air when not wanted, caused by loose connectors, loose mounting, slipping gears or output ‘hex’ loose.
Couldn’t have written that yesterday, didn’t know that much, found out since from French language forum.
weety
strewth found it......and i found a clue as well!!Clogzz wrote:The flap motor is visible and accessible from the passenger’s side, stuck against the carpet, at the very back of the centre console.
anyway strange coggy looking thing located....i started the car up adjusted the temp control from one side and nothing at all happened to the cogs (are they meant to move?) with my fingers on them i couldnt feel anything moving either...
then i found a clue
so how does this controller work? it looks somewhat complicated
Clogzz
- x 40
It won’t be rocket science, despite the looks of it.
Apparently a stepper motor with reduction gears to turn to flap in both directions, depending on the polarity.
There’s nothing moving around the outside, it’s all enclosed gears, except for the output shaft, which has a hexagonal driver to move the flap.
weety
excellent i can almost feel the bodge coming together now
so (assuming i can remove the motor from underneath) i either have a knackered motor letting the flap move or a knackered power feed to it
so either replace the motor or wire my own switch into it
worse case scenario is that the motor works but but the flap has somehow become detached from the top of the driver
thanks for the help i think i will leave it to the weekend but i am a lot more confidant now
Clogzz
- x 40
Removing and refitting the motor looks like it may turn into a circus, or a contest of swearwords.
From what I understand, faults are ‘timing’ between output cog and flap.
The reduction gears may slip, and the flap intermediate plate worn in the hex recess.
Maybe try the motor dangled outside, and grab the hex if and when it turns, to check for slipping gears.
Moving the temperature slider from cold to hot should operate the motor, because it looks like the flap mostly affects the flow from the heater.
