any easy way to stick the side trims back on when they have
ricflair
Unread post by ricflair »
Snapped off!.
I was just parking my car, and because some idiots dont park within the lines, i was forced to try and get as close to the pillar as possible in the car park on the other side. Anyway, refersiing in and it slightly caught the trim, forcing it off completley. It looks as if the clips have snapped, is there anyway i can get this back on?
jmd
Unread post by jmd »
Replace the broken clips. Those can be got from your dealer. You will have to remove the interior door trim to do the job.
dnsey
x 19
Unread post by dnsey »
A 'quick and dirty' alternative is silicone sealant.
Just use a thin layer, and hold the trim with masking tape overnight to allow it to cure.
alan s
RIP 2010
x 6
Unread post by alan s »
Here's an option I slapped in the Handy Hints section of the forum in the past day or so.
I've been meaning to do that for a while now since I did a few around last Christmas and your posting jolted my memory.
http://www.frenchcarforum.co.uk/forum/v ... hp?t=21852
Alan S
RIP Sept 19th 2008.
She said "Put the cat out" She didn't mention it was on fire!!
weety
Unread post by weety »
small self tapping screws can do wonders.... though on closer inspection they can look a bit tatty :D
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
THELABMAN
Unread post by THELABMAN »
the clips are only pennies form the dealer and a pair of pliers prises out any still in the door, I had to get some for my n/s rear door.
Citroen C5 2.0 HDI SX Hatchback - 2002 (52)
Xantia Sensation 1.9TD (T) Mallard Green (Gone to the breakers)
