My recently bought 53 plate 307SW feels flat and unresponsive low down compared to my old X reg Xantia. This is despite having the same 2.0 HDi 110 engine. It's also worse on fuel. The Xantia did at least 45mpg, normally 47-49mpg. The 307 is only managing 42mpg
Different HDi Set ups - Cit V Pug
p20
Are there different HDi engines maps/set ups?
307SW HDi 110
rabenson
nick
Same with mine, the first time I gave it a thrash it smoked like a barsteward & great chunks of solid black soot fell out of the exhaust onto the road
Probably the result of 4 years with the previous owner doing the school run with a cold engine in heavy traffic every morning.
I've been giving it the occasional Italian tune up & using Millers diesel additive too. It just seems to be getting quicker, smoother and more economical all the time
p20
nick
It did take a fair amount of time (5000+ miles so far) before I started to notice any improvement. I have also disconnected the EGR, not that it made any apparent difference, but will help to prevent it getting clogged up in future.
I have cleaned the MAF sensor with some carb cleaner, a faulty MAF can cause lack of power on these engines but its worth trying a clean before replacing it.
KP
- x 27
KevMayer
My C5 seems to have become much more lively since I recently serviced it. I changed oil and oil filter as you'd expect. Then I fitted a K&N panel filter. I changed the fuel filter and the old one looked very grey with residue in the filter bowl.
I think my fuel filter may have been a problem prior to the service.
I also picked up a tip from a yahoo site which suggested that you check for slack play in your throttle cable. I took a bit of slack out of mine.
The result is a much more responsive C5 2.2 Hdi.
The fuel economy is still rubbish, but it picks up better and now I don't notice any 'normal' cars overtaking me or leaving me standing at the lights any more. So, I don't get depressed by it's performance like I used to.
Was it the K&N or Fuel filter or slack in the throttle.... I'm not sure. That's the trouble when you change more than one thing at a time.
cheers, Kev
cheers, Kev
Cheers, Kev
AndersDK
Brian UK
p20
Cheers guys. I do need to read up on this particle filter thing. If the economy doesn't improve i may have it remapped. Might aswell be fast if isn't going to frugal
Kev, where did you get your K&N filter from and how much was it? They only ever seem available for the boy racer brigade, or a bit of a bodge.
307SW HDi 110
np
I got my K & N from Euro car parts.£41 with the vat.They did`nt list it for my 406,but its the same as a Xantia TD`s,so got that 1.Have a look at knfilters.com for part numbers.A lot of Peugeot/Citroen filters are the same.
My 110 hdi was good on performance,but its great since i had it remapped to 140 bhp ish.Also gained about 5 mpg ish.Can often get over 50 mpg from it on a mixture of driving.
53`406 est SE Hdi 140,110k
p20
np
Sounds like it but i dont have a p;artical filter on mine.I had mine done by a bloke called Will,in Wolverhampton,through ebay.
http://myworld.ebay.co.uk/performance_torque
Very good he was too.
DickieG
- Monaco's youngest playboy
- x 38
There are different engine management systems used on 2.0 HDI engines, the majority were Bosch EDC15, whilst others used Siemens Sid 801.
I believe the Siemens version doesn't have the additional fuel pump in the tank, which due to well reliabilty issues is quite a blessing really.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
lolingram
- RIP 2010
Has anyone had positive results from re-mapping the 90HDi engien? My Xantia is wonderfully frugal, but a little more urge wouldn't go amiss. I do not want to spoil the economy aspect.
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
