glow plug spanner
weety
glow plug spanner
Unread post by weety »
just about to do my xantia glow plugs but cant find my er engineered glow plug spanner for the one behind the fuel pump (placed spanner in vice hit with large hammer multiple times :evil: )
i seem to remember that someone brought out a 'proper' spanner to do this does anyone have a link to where i could get the tool?
Cheers
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
wrinklet1
Unread post by wrinklet1 »
I did mine ad did similar to you, I bent a ring spanner to fit the glowplug. I was quite a simple though knuckle ripping job.
Paul
1xAmi,3xGS,2xBx,2xAX,2xSaxo,1xXantia mk I,2xXantia MkII,1xC1,2xC2,
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
The name of the spanner you're looking for is called an 'Offset ring spanner' which should be available at any reasonable car accessory shop/Halfords etc.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
davethewheel
Unread post by davethewheel »
i tried an offset ring spanner but the bend wasn't quite right so i just bought a cheapo spanner and bent it myself.
weety
ahhh offset ring spanner (such a better sounding name than 'one i bent in a vice').....
now if somebody could invent a cunning knuckle protector hmmmm
AndersDK
Unread post by AndersDK »
deep offset ring spanner :?: :lol:
Anders (DK) - '90 BX16Image
weety
AndersDK wrote:deep offset ring spanner :?: :lol:
to technical for me....you mean hammered in two different directions :shock:
AndersDK
yes -
two (2) possibilities to snap the spanner while hammering on it :lol:
weety
you mean two opportunities to impale a spanner into my hand (after missing with the hammer) :D
AndersDK
weety wrote:you mean two opportunities to impale a spanner into my hand (after missing with the hammer) :D
I cant believe you deliberately wants to hurt yourself again - after the first try :lol:
weety
i drive a xantia...... i used to drive a bx td (without an aftermarket temp gauge) before that i had a 650 Visa......... masochism is my middle name
reblack68
Unread post by reblack68 »
They are sold as Glow Plug spanners but people on here who have used them don't seem that impressed IIRC. I've never used one.
Here's the one that Screwfix do but I think you'd get theme anywhere that sells tools.
http://www.screwfix.com/app/sfd/cat/pro ... 1&id=30736
Richard
Care of a 1994 205 D.
x 1487
That screwfix one wouldn't go anywhere near the plug behind the injection pump :lol:
Thread here about changing Xantia TD glowplugs: http://www.frenchcarforum.co.uk/forum/v ... hp?t=20675
I've bought a nice set of really deep offset ring spanners from my local motor factors - I've still got to change the difficult one in our ZX :roll:
x 94
Unread post by citronut »
the LIDALs cheap set of cranked spanners are quite good as well,thats when they have them
regards malcolm
andmcit
x 30
Unread post by andmcit »
You know, you can actually turn the glowplug behind the pump by using
a normal flat spanner from the middle of the head's direction. The offset
ring 12mm from Halfords was handy to have to take the initial grip off it
and to tighten the new one in mind and it wasn't too hideous a price tag
at 3-4quid.
IIRC I need to thank Richard for his advice about cutting a slot in the feed
wire ring as this worked a treat - I'd never done this job before and it only
took about 30-40 minutes. Maybe I managed due to being properly
mentally prepared after reading every word on the subject here first!!
The job went OK with the only hassle when I dropped the old glow plug
down behind the alternator never to be seen again AND I did manage to
drop a new one wiggling it into the non space behind the pump although I
managed to retrieve that one!!
I also used a handy telescopic magnet that stopped any nut/washer going
'walkies' when undone. The new plugs made a fantastic/significant
improvement in the starting on my TD estate though - transformed it.
Andrew
