On the way to GSF today however, there was a constant low squeal, really really annoying!
So I decided to bite the bullet and put my trust in the BoL and take the rear calipers off to see what was causing it.
The BoL actually covers it well, and it's an easy but long winded job.
I popped out the old pads and saw that they were worn down nearly half way, except at the top which was hardly touched so they hadn't been seating properly anyway and some of the squeal could have been this "lip" rubbing the outer rim of the disc.
The wear was also at an angle / and so was the wear on the disc!
Looking over the top I could see the caliper was just touching the disc.
The same was true on the other side of the car.
Followed the BoL and removed the calipers. Of course it was lying and gave the impression that once the bolts and brake pipe were out, it would be easy.
Heck no!
After much wigging and disc turning, I managed to get them out.
There was a thick layer of white corrosion on the calipers and where they mate against.
I scrapped this off and re-fitted the calipers and pads.
Not a sound from them now!
