is it possible
meexi
is it possible
Unread post by meexi »
my rear calipers have suffered from the dreaded corrosion and tilting and would like to know if it is possible to swap the left hand and the right hand calipers as they appear to be mirror images it would appear that they are not handed
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
AndersDK
Unread post by AndersDK »
Yes they should swap from side to side no problem.
- provided you swap the bleed nipple for the feed pipe.
Dont part the caliper into halfbodies. Instead :
1) remove pads
2) re-fit pad screw and nut.
3) unscrew feed pipe & bleed nipple
4) unscrew caliper bolts
5) slide caliper clear of brakedisc and clean the mating face on the rear arms.
6) seal off the mating faces using sticky rust protection mass or silver (alu) paste. Copraslip or copperpaste is not good on alloy surfaces as this will cause electrochemical corrosion by itself.
Anders (DK) - '90 BX16Image
