I need to replace the rear pads on my daughters car. Had a quick look and just wondered if someone could confirm you have to turn the pistons to get them back into the caliper? I think it looks similar to the front pads on a bx I once had . I remmber something about leaving the cut in the piston at a certain angle.
David
306 rear pads
Brian UK
AndersDK
There is a matching pip on the inner pad to fit the notch in the piston. This decides the position of the piston and prevents the piston turning. Otherwise the self-adjusting handbrake mechanism may cause the piston to turn.
Might not be exactly the same design as found on the BX. But the function is exactly the same.
The BX front caliper :
http://media.thg.dk/DAT/pic/l/751214826700.JPG
306 rear caliper :
http://media.thg.dk/DAT/pic/l/701616966710.JPG
306 rear caliper :
Anders (DK) - '90 BX16Image
David Humphrey
AndersDK
