ZX TD - Water Pump
sooty
ZX TD - Water Pump
Unread post by sooty »
I know this might be a daft question,
But which Water Pump listed at GSF is for my 1996 TD Elation as it lists 3 pumps which to choose from, I don't know what my RP is ??
Where would I find this RP number on my car, I can see my paint code on the L/H suspension turret.
Ex 307 2.0Hdi 90 bhp 2003
Ex Grand C4 Picasso VTR+ 2008
Ex Vauxhall Insignia SRI 2.0 CDTi 2010
C4 Picasso 1.6 HDi VTR+ 2014
sooty
Has anyone needed to have their RP number, if so where is it found on the car.
AndersDK
Unread post by AndersDK »
Hi sooty -
from this table :
http://www.gsfcarparts.com/downloads/citrpguide.pdf
You can reverse-generate the RP number range for a Citroen.
A '96 produced Citroen would have an RP number in the range :
6993 - 7358 (jan 1/dec 31 - 1996)
Exactly where the orga (rp) number is printed I donno on the ZX. My guess is on either side's suspension turrett in the engine bay - or on either front door pillar near the interior lights switch. On the CX and all the BX'es I've owned, the number was stenciled on LHS front door pillar as described.
Some of my BX'es had no numbers to be found.
Note that a good cleaning / waxing easily rubs away the stencilling :roll:
Your cars VIN number may be used instead. This will also be found on the papers/documents for your car.
Anders (DK) - '90 BX16Image
x 1430
Just been to look - on ours it is stencilled in yellow paint on top of the N/S (left hand) suspension strut mount, not far from the paint code which is in white paint.
I suspect you will want the middle one of the three pumps - I guess the first will be for clip on belt covers, the second for bolt on covers, and the third for very late cars 1997 onwards.
jeremy
Unread post by jeremy »
Same place as Richard's - and dirty yellow. In fact its rather poorly painted and the number I originally thought it was would have been impossible - but knowing the range it should be in enabled me to get it right.
jeremy
sooty
Thanks all,
I've found it, its in yellow on top of the L/H strut as said.
Its 6976, so from Anders link that puts it as being made between 1st Dec 1995 and 1st Jan 1996 which would be about right as it was registered 04/1996.
Thanks again :D
